2g Weight Reductions! Weights included!
dsmornothing
603
11
Jul 23, 2009
Ishpeming, Michigan
Alright, so there really is not much info on what everything weighs in a 2g. I spent Hours stripping my car and weighing everything i pulled. So i figured since im having a boring night at home i might as well make a thread about it! The project is still not completed and keep in mind weights on some things can vary car to car. I will continue adding more to this as i remove it and weigh it all! Alot of you might be against gutting a car, but in my eyes every little bit helps, and you cant forget how much it will help your drive components!
Firewall padding (thick rubber coated junk) 15.5 Lbs
Blower Motor and Housing- 5.5 Lbs
Heater Core- 10.25 Lbs
HVAC Controls w/Cables- 1.5 Lbs
All Vent Ducting under dash- 3.12 Lbs
Passenger Airbag- 10.6 Lbs
Steering wheel bag (off wheel) 5.15 Lbs
Stock Radio and Amp- 10 Lbs
Auto Cruise ECU- .45 Lbs
E-brake Handle Assembly (for those who can live without it) 3 Lbs
Airbag Computer and Braket - 2.25 Lbs
Sound Deadening (Entire car front to back) 27 Lbs
Carpet Padding- 2 Lbs
Rear Seat Bottom (Leather)- 10.5
Rear Seat Back rest. 9.5 Lbs x2
Lower Side Panels in Back seat- 3.5 Lbs x2
Random metal Braket behind rear seats- 3.5 Lbs
Spare Tire and Jack- 35.4 Lbs
Washer Fluid Resevoir and All Tubes- 5 Lbs
Hatch Panels (sides) 4 Lbs x2
Rear Wiper Motor, arm and blade- 6 Lbs
Rear Seat Belts together (not with lower clip portion) 5 Lbs
Front Seat Belts Together- 6.5 Lbs
Exhaust Dpipe Back (mine was 3 inch from your average muffler shop) 67.5 Lbs
Entire AC system- 42 Lbs
Stock Battery- 42 Lbs
Stripped Deadener/Sealer from inner wheel wells. 24 Lbs from what i collected.
I Also stripped Every wire out that would no longer be used, i ended up with an AMAZING 24.6 Lbs!:hellyeah:
Hell yeah, thats one thing i didnt do when i gutted my car was weigh everything. Looks like about 360 pounds you stripped so far. I have taken out just about everything you have on that list. The only thing i didnt do was the ebrake, wheel well junk, and exhaust.
I know i mentioned it in your other thread but getting different front seats will save you a good bit of weight as well. If you are up to it i would do a full wire tuck and delete all the wires you dont need from the engine harness and front chassis harness. i saved around 10-15 pounds just in wire and old loom from those two harnesses. This winter i will be doing the rest of the wiring.
Keep up the hard work and update us with the weights of anything else you yank out.
Well as of this day i know i have over 600 Lbs out of the car between the fuel cell and yes i even got some BEAUTIFUL Bride seats!I will be adding photos and more numbers along the way! Aiming for 2700 Lbs. And if you see the veryyyy last thing on the list about the wire, it may suprise you a bit!
Dont forget the Impact beams mounted behind the front and rear bumpers, there a good 30 or so pounds each. Get em out and weight em for us!
you can mount the front and rear bumper back up and you'll never know they have been removed.
Keep us updated!
