2g Stainless Steel Clutch Line in a 1g?
VeryFast2gDSM
61
Mar 22, 2009
Buffalo, New York
I would like to replace my 1g Hard line with a full 2g SS Clutch line. What is needed to do this? Is it a bolt on affair? I remember the end that connects to the Master Cylinder is different correct?
Nevermind... Found it on SBR
2G Complete SS Clutch Line - MASTER CYL to SLAVE CYL
They come in the perfect length for your First, Second Generation DSM or now even the Evo VIII. They are a direct bolt on that will instantly make your left foot feel more comfortable launching that Mitsubishi hard! They are made to be a perfect fit and can be bolted on usually in under an hour! This is a complete line that goes from your master cylinder output the entire way to the slave cylinder."
Buy the 2g. It eliminates all of the soft lines. It'll connect your slave to the connection on the frame.
dredman1 said they make a 1g specifc one now... Extreme PSI sells them.
But I believe its just the same line for 1g and 2g since SBR says they work with both generations...
I was going to buy the line from extremepsi yesterday, but realized they are charging $20 for shipping and handling on this $40 line. wtf? Im doing a swap, i think ill just go to the junkyard, get the hard line for a $1 and replace the rubber hose with the $20 stainless.
$20 shipping?? :confused: Unless you needed it urgently and chose expedited shipping, you should have only had to pay $7.50.
I bought mines about 2 weeks ago from them and I got "free" shipping on my order (using their standard ground shipping option). It was delivered in 3 days time.
You still have to pay a $7.50 "handling" charge on all orders from them, but $47.50 still works out less than anywhere else I saw the SS line being sold. It was even better for me because I bought several items from them in that one order where I bought the line, and I was charged $7.50 for the entire order of several items :thumb:
I just went back through it and and seen you could do the free shipping. I didn't catch it the first time and thought the $12 was the cheapest option.:ohdamn: The $7.50 is more reasonable and will get my business:thumb:
Yep, I'd definitely recommend getting the line from them. It's top notch quality.
The braided stainless steel has a clear coating on it so you can easily handle it without getting stuck from the braided part, and it's the perfect length to run along the entire length of the old hard line - out the way of any moving parts. You get a new banjo bolt and copper washers to seal it too (wasn't expecting that)!!!
