2g side skirts
roostinds
65
Mar 2, 2009
Sylmar, California
Is it hard to take them off. My car is like three different shades of sliver and want to paint it all the same. Front bumper and side skirts.
Not all are clips. The door caps yes are all just held by clips and double sided tap. pop and pry.
however the actual side skirt and END CAP of the skirt there are IIRC some bolts underneath or a combination of those plastic push to lock, unscrew and then pull out to remove. I'm sure its just bolts though, but correct me if im wrong.
Now that you mention it the rocker cover has a few screws that you get from underneath and if I remember correctly the end cap has a single 10mm screw holding it in place.Bottom line is all the fasteners are visible and once off ,just pull off the parts carefully so the clips wont break.
Is there a difference from the 2ga and the 2gb side skirts and rear bumper. I know the rear bumper is a little different but i don't know about the side skirts
Visually yes they are different.
But if you have a 2ga skirts and you want 2gb or the other way around.
They will bolt and snap into the same holes that the factory used to install them.:thumb:
I found the side skirts for my 2GB at the auto wreckers and installed them, after a little drilling. The original side skirts had plastic clips on the sides and square inserts on the bottom, where you could use machine screws. I used the clips on the sides, I just drilled smaller holes on the bottom and used machine screwas alone and it holds fine. Yes, they are easy to take off, but don't pry against the clips. Ease the sides off after unscrewing the bottom.
3-pieces per side, the smaller front piece has a bolt holding it, I think 10MM.
