2G Shifting problems, Clutch?
ShadowXAlpha
37
Feb 27, 2005
Grafton, Wisconsin
OK. So out of the blue, my shifting starts acting up today. I know this usually happens when it is colder out, but its already been alot colder this season, and i havent had problems. When at a standstil, the car wont shift into first. The car is fully warmed up. Its stiff shifting into second and third as well. I just read up on this, and some posts said to adjust the clutch master cylinder. Did that, still have problems. Also, when the car is off, in gear, and clutch to the floor, when starting, will creap forward, as if it isnt fully disengaged, even after i adjusted the master cylender. Feels like its grabing up around the top of the pedal now... I have no idea what it can be. Im thinking i may need a new clutch? Or is the master or slave cylinder going bad, or a combination of all? Any help would be greatly appreciated.
Thanks
Rob
Check to see if either the slave or master are leaking. Try adjusting the pedal more though if they appear to be ok.
