2g roll stop mount location
matta
105
5
Aug 20, 2012
Gilbert, South Carolina
Does anyone have a picture of where the 2g roll stops are supposed to be mounted at? I have a 96 gsx manual transmission. Also doing the 6 bolt swap, I can still use the 2g roll stops right?
so they basically just float on the transmission...they dont mount anywhere to the subframe? I've tried searching and have come up empty. what mounts to the vertical brace that goes from the firewall to the radiatior support? I see four holes, has to be a bracket that's supposed to mount there
A 2g tranny has two mounts. ONE on the rear with attaches to the front cross member right by the fire wall. The other mount attaches to the subframe between the tranny and the radiator. The subframe which goes from under the passenger side to the front clip.
You can see the two brackets off the transmission for the front and rear roll stops in this picture.
You can see where the front roll stop attaches to the center member in this picture (left center member, just behind the S).
You can see where the rear roll stop attaches to the front crossmember in this picture (look for the red Prothane insert and the shiny bolt head).
