Spyder 2g recommended upgrades
mkoldus1
Jul 28, 2021
Fishers, Indiana
Hello everyone i am a 15 year mercedes tech that just got into a 99 gst spyder 5 speed. This car sat for 3 years with a blown clutch. I installed a new clutch and master cylinder. I did the necessary maintenance items ( car has 130000) so didn't know history did the the timing job, changed oil, coolant, took the pill out of the boost solenoid, swapped the internal Wastegate to a 1g, put in a new air filter kit, also a boost gauge. The car consistently makes 12 lbs of boost and I can tell it runs slightly lean in the upper rpms around 6500. I know ill need injectors but what else would you recommend? My goal out of the car is a really fun daily with max performance goals around 300hp. I know with front wheel dr that's really all the power that can be used. Thanks for the read and I appreciate any posts.
