Resolved 2G Plugging the original turbo oil feed line?
red eclipse gsx
109
3
Jan 18, 2004
Chalfont, Pennsylvania
Hi, I just installed a FP3052 turbo (with all supporting mods) in a 2g and I have a question about plugging the original oil feed line from the T25 turbo that I just took out. I tried to put a small hose over it and plug the other end with a screw (all connections tight) but the oil pressure seemed to be too high and it just popped off. How has everyone else plugged their lines? I've searched for this. Thanks.
Does the oil feed on a "99 come from the same place as a '95? If so , You should be able to use the plug from a 1g N/T head to plug where the banjo bolt is.
Mike
Thanks for the tips guys. I used a SS line from forced performance off the head. And luckily I do have a bolt that may fit.
