2g passenger lock works, window doesn't
LRS95TSI
450
4
Nov 9, 2004
louisville, Kentucky
i searched and the wiring diagram for the windows is no longer available. both door locks and the the drivers window works fine, but the passenger window isn't working. How do i determine if it is wiring or the motor? i switched the buttons out with a known good working one and nothing, and the drivers door passenger button won't work. what colors are for the window wiring?
well I would start off by removing the pass door panel and get access to the window regulator. Unplug the connector that goes into the regulator and either use a jump pack or a 9 volt battery with jump leads to jump the regulator itself. if it goes up or down then the regulator is fine, and you can move onto wiring. if you have a hanyes manual you can look in the back of it and it shows the wiring schematics for everything, just in case it is a wiring issue.
could be the motor/regulator. rul etha tout first, then find a known good switch and try it.
then its chasing wires
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
