2g oil squirter location
i dont understand what you mean by " i cant find the oil squirters ON my block" as the oil squirters are not one the block they are internal in the engine. just by looking at the block theres nothing to give hint to whats inside. what are you needing to know where the oil squirters are for? if you had the engine torn apart you would see them.
They are screwed into the main journals of the block, directly above the crank. They don't have an angled nozzle like the 1g squirters, they are screwed in holes that already point up at the pistons.
They are not screwed in, they are a press fit thru the main bore.
oh i see..i was looking at the side of the block. i didn't know the location. thanks i will look at mine tomorrow. do you usual replace these every time you have the block apart?
