2g Oil Press Gauge Tap Location
Status
Not open for further replies.
daren_p
DSM Wiseman
4,605
98
Nov 22, 2004
Newmarket, ON, Canada
I was going to just install a T fitting where the factory oil pressure sensor is & when I got under the car it looks like there are 2 sensors. There's one thats closest to the front of the car right beside where your turbo oil feed line comes from then there's one closer to the firewall, the sensor itself has a larger housing. Which one is better to tap into? It would be easier to tap into the back one as there would be more clearance but are they fed from the same location? (will they give you different pressure readings, are they both freshly filtered oil?)
Status
