2G no spark!Please help
Lucky97GST
Sep 23, 2004
Eugene, Oregon
My stock 4g63 with few mods(see profile) will not start up. It turns over, i can smell the fuel going threw the system, everything electrical works, everything works but car wont start up, everything checks out? no blown fuses, i cant figure out whats wrong. Havent had the spark plugs changed, could it be the starter? The car has 89xxx miles. I did a search and tried to find other people with problems like this, and i came up with some helpful ideas but nothing that was like my problem, they had done JDM swaps and focused on mating the new motor with their cars electical system. Please help, just want the car runnin again. :confused:
Check your Ignition Power Transister, its between your TPS and your coil pack. Its possible that it could have backed off or gone bad. With out you IPT you will not get any spark. Good luck
i am having a similiar problem but this is my first dsm, and i dont have any manuals on it. where is the tps sensor and what should i check for on it or the cam angle sensor. sorry i did not mean to thread jump, but this thing is killing me and i do not want to just buy random parts that dont fix my problem. :dsm:
there are two plugs in your wiring harness you can test the plugs for a signal or you can test the wires goin to the plugs but if your haveing spark trouble check the crank angle sensor if its fuel injector signal check the cam angle sensor. :dsm:
