2G Mass limitations
4G63conquest
Sep 9, 2009
Brunswick, Ohio
I was wondering what happens when a 2g Mass is maxed out. On my logger for the last 500 rpms in 3rd gear my hz reading stays at 1603.9. WTF? Any help on this would be great. Should I remove some honeycombs? I also have a 1.5in k&N laying around that I can put back on the intake pipe after the mass. I used to run this because I had a hacked 1g air flow sensor. Also I was wondering if hacking it would give me a little less timing when cursing around at part throttle. Thanks in advance hope U guys can help me out.
I believe that the logger is maxed out not the maf. That is the highest value the logger can read. The logger on my 1G is maxed at the same value.
Thanks guy for the response. I didn't think I was overflowing it but was dumbfounded by the number. I have been using mmcd because I can set it up to beep when it knocks. I am about to take the plunge on the ostrich converter and get jackal to log and tune with. I would like to extract that last bit of power out of it and feel that would be the best means to do so.
