ECMlink 2g log advice
obx tsi
199
Dec 1, 2005
Manteo, North Carolina
Need advice on how this log looks. New to the tuning aspect and would just like some feedback. Thanks.
First,
https://www.dsmtuners.com/threads/w...r-receive-no-replies-from-the-wisemen.443297/
Now on to your log.
- Manually adjust the TPS. You are compensating too much :sneaky:
- Are you on speed density? because your ECU thinks you are, but you have MAF compensation done too... SCRATCH THAT> you don't have the sensors to run SD according to your ECU inputs tab. Please uncheck "disable MAF compensation with S/D" on your maf tab.
- You shouldn't need to use the fuel sliders other than quick tuning. Then you make the compensation in your SD table or MAFcomp and zero them out.
- Your AFR tables look pretty hideous. 9.5 is realllly rich. You can use these tables to start with: http://www.dsmtuners.com/attachments/stiggity99directaccess-eda.303436/ I had success with the fuel tables and slightyl less timing than OEM 2g timing table.
-Your WBFactor looks good.
- Your ISC is way out. Target is 30 with no accessories on
- LTFTMid is more out then I would like but not horrible.
That's all I see so far.
