2G 2g koni adjustable and eibach springs
old wrench
Oct 2, 2016
Vallejo, California
Got it running! Pretty quick for all stock except for a 14b and cat back.
My question is regarding ride quality or lack thereof, this thing rides like it has no suspension!..super stiff!, mostly the back, pushing down on the back bumper I get no movement at all. Its got koni yellow adjustable shocks and eibach springs. The number on the rear springs is 0700.250.0300 . Before I go back to stock is there any way to make this setup ride better for a daily?
Turn the rebound back some. This will make it "feel" less stiff despite compression not changing. It shouldn't have to be full hard with eibach's anyway. I never run my full hard and my spring rates are 3 and 4 times as stiff.
Sounds like you have them tuned to fill stiff. mine are not *that* bad when set to soft, and I'm on the eibachs. Word of caution though: if you want to run a bigger tire with this combo it won't work. ;)
Thanks for the replys, is counter clockwise on the adjustment softer? Also from my researching, a 300 lb spring on the back is double what the stock spring is. does that sound rite? It's so stiff rite now I can't emagine 3 or 4 times stiffer.
