2g key fob keyless range
chrysler kid
3,552
1,150
Dec 20, 2002
Mckinney, Texas
So on 2 separate dsm's I have broken door handles entirely due to the key fob range. To lock or unlock sometime I have to literally hold the key fob over the winshield to get the car to lock or unlock.
The key fob is in like new condition with new batteries, tested with rf key tester
So do any of you have exceptional key fob range, or any knowledge on where the rf receiver is located in the car?
range should be about 20 feet.
There is no external antenna or anything.
Again thank you for the info. Do you have a pin out for the plug that goes into the unit
The black NEC relay looking box appears to be the rf control unit. In your pictures what Is the approximate age if the device, hopefully I'll just need to clean the board and maybe a little new soldier on the connectors
its from a 97 or 98. here is the pinouts
here is the section out of the tech manual
