2g install kit on 50 trim
Gst-star
Jun 9, 2009
Watsonville, California
i hav a 14 b with an extreme psi 2g install hit. Now im looking on buying a bullseye power t04b 50 trim any moment now and would like to kno if i can use my oil feed/return lines from the install kit or what would i have to do to make the lines work on the 50 trim. Any help would b greatly appreciated. thnks!
If you have an aftermarket feed, you will just need the correct fitting to bolt it to the turbo.
Return line from a 14b will definitely not work...the turbo should come with a return tho. If not, ask the place you are buying it from about getting it with it.
I have had nothing but oil cooled only turbos since 2005 and I even have the water pipe modified so that I don't have water lines for the turbo anymore...I even ran a 16g for about 5 months with oil only.
I always turbo time my car 2 minutes...to some it may seem excessive but no need for a turbo timer if you're only using it for 30 seconds ;)
so were could i find the proper fitting? have u tried this before?
There isn't a need for coolant to circulate through a turbo. Obviously if there are provisions for them, use it if you can. All it does is helps pull heat out of the center section to prevent coking. There isn't truly a need to idle your car unless you can't control yourself to stay out of boost and let the turbo cool down a couple miles before your destination.
It'll help a little to have your car idle in place, but heat is still going to stay in the bay and there isn't a signifigant amount of cooling power with just fans alone compared to airflow at driving speeds.
Automotive stores....maybe extreme psi (Welcome To Extreme PSI)
Yes, I have done this, I went from a t25 to a 14b to a 50 trim to a t28 to a 16g and now back on a 50 trim... :)
so i would just need the fitting to the turbo? ok do u kno which one in specific or can u point me to the right one if possible i would appreciate it that way i can save a few bucks.
