2g injector will not fire....
M1L3S
132
Apr 1, 2012
maple grove, Minnesota
2g injector not firing all 4 will not fire.
ive checked fuses(all the ones i know to check)
how do i check cam sensor is good?
car was given a base map, would that effect injector not firing?
car ran amazing until chip was reflashed.......
also did a compression test and it was fine, hasent started after that and chip reflash:cry::banghead::ohdamn:
Is it a stock CAS? If its 1g black or green top CAS I just unbolted it from my 2g and spun it. You should hear fuel pump running and injectors clicking. Make sure you disconnect coil pack. I had this issue and it was all 4 of my injectors clogged at same time from car sitting for over a year.
  • Wanted 6 bolt NT water pipe
    • chrisman287
