1G 2G Injector Plug on a 1G How-To
Ok, this is a straight forward "How-To" on the replacement of the 1G injector clips for the much easier-to-use 2G injector plugs WITHOUT RE-WIRING!!!!
Here the basic differences are noticable by the 1G having the wire clip to hold onto the injector, while the 2G doesn't, it uses (2) tension clips to hold them on. This is the basis for the whole project, just simple ease for the dsmer!
Just a quick view of the plug(s) I cut from a 2G harness at the yard.
First thing to do is use a small flathead screwdriver or a metal pick as I did, and just gently pry the gray clip off the back of the 2G plug from both sides. I found it much easier to release the single tab first, then the triple tab second, then it will just fall off.
Good picture of the instrument used to do most of the work.
This the first of two possible ways to release the wires. This way you simply go into the slot above the pin and put pressure in a outwards manner (away from the plug) to release the small plastic clip inside.
Here you just want to put some light pressure , pulling the wire away from the plug, and with some movment of the pick, it should release fairly easy, and pull out from the back.
The second way you can do this is to come in from the back and release the inner tab that way. I don't recommend this as the small rubber wire guard could be damaged in doing so.
This is what you should have after releasing the wires to "discard" and retain the plug and gray clip for use on the 1G harness. This same procedure is used to release the 1G clips after pulling the wire clips.
Once you have separated the wires from the plugs, simply plug the 1G wires fromthe harness into the 2G plugs, snap the gray wire holder back onto the back of the 2G plug and push onto the injector, and your done!
Best part of whole project is it only cost me $1.18 for all four connectors at the junkyard!
Hope this helps everybody! Also like to thank "DSM or Alphamale" from Niles, MI for the info!!!
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
