2G FMIC Install Q. What Distance between legs to go around the radiator?
rowlex
1,298
28
Apr 12, 2003
Everett, Washington
alright 2G guys gimme some info here :)
Installing a FMIC on a 2G what U-Bend leg distance would be best to round the radiator with: 4" or 6"? I don't want to go to far because I have an o2 dump. I'd rather not have to cut a U-bend to install a coupler, but If i have to..i have to. Let me know. TIA!
From center pipe to center of pipe on the u-bend. Also need to know what size piping you are using.
Draw me a pic or circle the spots on a u-bend pipe. I will measure for you. I have this type of intercooler piping right now and will be glad to help you out.
dude thanks a lot!! I was starting to think no one was going to post such a simple answer. I really appreciate your help. Here is a picture ->
i know this is not a U-bend. But you can see that one side is going to be around 2-3" inches and the other can be 6"
I will measure mine tomorrow. It is a 2Gb bumper on the eclipse. But I retain the stock fogs. Is that a requirement for you?
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
