ded_gone
- 0
- Nov 26, 2005
Manassas,
Virginia
Alright, this is the first time I have tried to post. I've tried looking for info on my problem and talking to dealership tech's.
I had a problem driving down the road when my car seemed to lose power. I pulled over and it was idling about 400rpm. I turned the car off and checked a few things and found nothing apparent. I adjusted to idle control up so I would idle properly and proceeded to return home approx. a mile down the road. When I pulled onto my street my engine just shut off but my auto timer started counting down. After that it wouldn't turn over. I checked fuel and spark neither of which I was getting, so I replaced my fuel pump and my coil packs. Still nothing.
So I proceeded to find more info and decided to replace my crankshaft position sensor which are known to go bad on 2g 4g63t and still nothing. The only other two things I can think of are the cam angle sensor and the ECU. Unless the auto timer was spliced into the wrong wire off of the ECU for the speed sensor wire.
Any help or suggestions?
By the way i have a 95 Talon TSi AWD. My mods list is up to date with everything in the car.
