2g eclipse headlights in a 2g talon
kiddenvy
60
Apr 22, 2005
brighton, Michigan
Ok so i had bad water damage to one of my headlights so i decided to upgrade to a set of projection lenses. I Get them in a week ago, decide yesterday to install them with the nice weather and upon doing so i notice the back of the projectors have 2 plug and play pins that are both 2 pin plugs, one on low beam and one on high.. My original headlights only have 1 plug for both.. Is this common? And does anyone have a solution or pitchures of there wire modification.. Thanks
These are the pics of the new headlights and a pic of the old talon light you will see 1 set of wires form high beams, one set from low and the positive and negative from the halo on the new lights and on the talon light you will see one harness located on the bottom.. <img src="http://i6.photobucket.com/albums/y239/kiddenvy/2006_0328Image0005.jpg"img><img src="http://i6.photobucket.com/albums/y239/kiddenvy/2006_0328Image0004.jpg"img><img src="http://i6.photobucket.com/albums/y239/kiddenvy/2006_0328Image0002.jpg"img><img src="http://i6.photobucket.com/albums/y239/kiddenvy/2006_0328Image0003.jpg"img>
Yea I have the same headlights. What I done was took the harness out of the stock headlight which you will need to cut them and pull them out it's not hard at all or you can go to a parts store and but the harness for 9005 and 9006. I think they may not be colored match like the stock ones are.:thumb:
