2g Cyclone Intake Manifold questions
GloriousDSM
271
3
Feb 9, 2006
Sterling Heights, Michigan
I have 2 questions if anyone can chime in,
1) Does the cyclone have any vacuum ports underneath that are not visible from the top?
(motor is already in and i cant see the back of the intake mani)
2) What port goes to what vacuum line or source on a 2g?
If anybody has some photos or knows where i can find some info that would be wonderful, thank you.
-gold
-gold
To properly hook up a cyclone manifold without the JDM computer, you will need a good vacuum canister and either need DSMLink or an RPM switch to activate a solenoid that feeds vacuum to the flappers. Any source that will provide vacuum to said canister will suffice.
Also just an FYI, not sure what cylinder head you have, but the ports on the cyclone manifold are significantly different than the factory ports on a 2g cylinder head.
  • Wanted 6 bolt NT water pipe
    • chrisman287
