Resolved 2G connector id
Black connector is rear O2 sensor.
I see the auto's Overdrive switch is on the same harness downstream of the O2 sensor connector. It's six wires and that doesn't appear to match the white connector you have there.
I am pulling my hair trying to read this manual, any gurus out there feel like making life easy on me and naming these connectors. Also is wire bracket correct on the alternator ?
1 - Power steering pump
2 and 3 - One is for the oil pressure gauge unit (big brass bell shaped sensor) and one is for the oil pressure dummy warning light (small acorn shaped sensor). You'll either have to check the wire colors on those to figure out which one is which (yellow w/ red stripe is for the gauge unit, plain yellow wire is for the dummy light) or take a stab at it by hooking them up and checking to see if the gauge and light are reading correctly -- if not, swap them.
4 - Condenser fan motor
5 - Fog light
6 - Can't see it well enough to tell
As to your alternator wires and bracket being in the correct place, they are. See post #46 here: 2g Engine Bay Electrical Connections
