2g clutch pedal swap
ebizzle22
Oct 20, 2009
Portland, Oregon
Hey guys, first post on the forums but I've been reading dsmtuners since the early 2000s...
So I've searched and searched and this topic has not yet been discussed. Basically, I want to know if I can I install a clutch pedal assembly w/out the assist spring on a 95 gsx? I pulled one from a 420a in great condition before realizing that all of the 2g 4g63's have the assist spring welded on. Is it really necessary?:confused:
From what I have read, I should expect slightly harder pedal feel after the swap. Is that all?
I have also read that older mustangs have to remove them to fix shifting at high rpm and swap them out for non assist spring pedals. In case you're curious, I am removing my assembly bc it is rusted out pretty bad. The car sat for way too long before I got it, :toobad: I can post pics of the 2 if necessary. Thanks for your time.
UPDATE: I just got an answer from jacks. They said it will be fine:rocks:
if anyone has any input feel free to post!
