2g AWD tranny output shaft no play Helpp!!!!
REDspydergst
53
Oct 2, 2011
San Diego, California
Long story short, I put together a stock tranny for my 2g but after I assembled everything back together the outshaft for the t case has no play at all. I know there is a ball that holds the shaft in place and Im pretty sure It was there when I assembled the shaft. I have no idea why it has no play. the tranny seems to spin right all gears can be engaged including reverse. Can any tranny master in here tell me if I should run the tranny even if the output shaft has no play?? I would hate to take it apart because I took forever building it since it is my first tranny build. Please help me I need this car to be running asap. Thanks. 96 gsx
By no play I mean no in and out play. I thought all good working 2g trannys have to have some in n out play for the output shaft. I even saw a vid showing a freshly built 2g jacks tramission tranny that had some play in its output shaft. Here is the link.
I dont understand why there is no play on mine, I feel confident I did everything correctly. What do you think synthetek??
Oh the shaft on my tranny turns smooth.
