Resolved 2G AWD/FWD SS brake lines
Omega
1,558
10
Oct 10, 2002
Randolph, New Jersey
This is for a 2G. Does anyone know the difference between the two? I know the calipers are different, perhaps it's the placement of the banjo fitting?
Lines are all the same if the car is equipped with discs all around. Rear lines are different for cars with drums in the rear
So the dual piston calipes have the line connected in the same place? Wouldn't the option be drum and disc as well as AWD/FWD?
Placement is pretty much the same. Brake lines are the same reguardless of fwd/awd as long as the car has discs all around. Cars equipped with drums in the rear have the same front lines as everyone else but use different rear lines.
They may list different part numbers for awd/fwd, in the end its pretty much the same parts. FWDs equipped with discs all around will use the same lines as an awd would.
I thought it would be slightly different somehow because aren't the front calipers on a AWD dual piston while on the FWD,they're just single pistons? Or is that irrelevant?
There's different fittings in the 2Gs compared to the 1Gs....one is banjo, the other is....I forget the term...
