98spydert
- 1,916
- 9
- Jan 16, 2004
Phoenix,
Arizona
I don't know much about the difference between AWD and FWD brake lines but I happen to have a set of AWD ss brake lines just sitting around and I have a FWD car. I'm using the 2G AWD front brakes, will the AWD brake likes work or do I need the FWD lines regardless of the calipers I use?
What is the difference? Just length or the fittings used? Thanks
From what I can sorta see those appear to be the correct lines. The two longer lines are for the front & the ends on the left side do appear to be banjo bolts. The two shorter lines for the rear are screw in fittings. You can also notice the small package that contains the actual banjo bolts & washers. They appear to be the same generic lines that most of the DSM vendors sell, so you should be set.
How'd you know I was a ricer??
