2g 7 bolt 2.3L stroker clearances.
Muzzled
34
May 14, 2011
Kitchener, ON, Canada
I'm curious to know what or if there is any clearancing issues with using a 4g64 crank in a 7 bolt block?
I have read about the 6bolt clearances but nothing about 7bolts.
I recently just finished putting together my engine and i haven't found anywhere where the rods come close to contacting the girdle or hitting the oil pan ( someone told me this a while back that it would.
Im using Eagle h-beams(older ones that required 6bolt rod bearings)
Wiseco Stroker pistons
4g64 crank
and a fresh machined block
with arp mains
Nothing touches at all, Id like to verify if this is correct or if somethings wrong.
  • Wanted 6 bolt NT water pipe
    • chrisman287
