2g 6bolt
mitsueclipse2g
71
Jun 3, 2008
Wethersfield, Connecticut
Hey guys, I have a jdm 6bolt that I'm swapping into my 2g talon. The motor came with the ecu and the wiring harness. My question is can I run the jdm ecu and the wiring harness that came with the motor? Instead of using my ecu and wiring harness and then have to do rewiring with the swap?
If I am not mistaken you still have to splice the two harnesses togeher.I have been doing some research there is a harness kit avalible just for this swap but I don not know who makes them.
No that's not what I'm talking about. That way is what everyone usually does, rewire the cam and crank sensor with the current harness and using the factory ecu. What I'm talking about is swapping out my whole factory harness and ecu and running the jdm ecu and jdm harness with the 6 bolt.
