2g 13g engine exhaust mani?
break911
30
Jan 17, 2005
Toronto,
Hey there,
Kind of new to my car/ Im pretty sure its a mistubishi jdm motor with a 13g stock turbo/ i imagine off an automatic awd/ is the exhaust manifold outlet smaller than the regular one (5spd)? will a 14b bolt on or do i need another manifold?
only asking cause ive heard otherwise somewhere/
thanks!
Like cruisin said above. It will help with flow just a tad bit more, not much of a difference though. Otherwise its all bolt on and play.
It will bolt up be be aware that the turbo oil inlet and return lines along with the inlet and outlet water lines are bigger on a 14b compared to the 13g. The lines may already be bolted on to your 14b still but if not extremepsi.com sells the lines. Have fun.
