272 or 280's
red97gsx
95
Jan 28, 2007
eastern, Connecticut
I'm building a street motor Here is my question. I have a set of new HKS 272's and a new set of BC 280's. I want to keep this car completly streetable, while gaining the most power at the same time. Opinions anyone?
Thanks,
Below are my specs on what i have done to the engine:
6 bolt block bored, linebored, etc (All engine internals balanced to .5 gram and crankshaft knife edged)
wiesco .20 forged pistons
Eagle rods
ARP main, rod, head studs
balance shaft elimination kit
Stage 3 head job with 3mm lash adjusters, SI double valve springs
new oil pump assembly
cometic head gasket
magnus intake
1g throttle body ported to 65
new FP exhaust manifold coated
new Forced Performance 3065 w/ o2 housing, 44 tial WG
3" exhaust no cat
GM MAF and translator
coil on plug setup
MSD DIS-2 with tach adapter
Race Turbonetics race FMIC with custom short route
twin Spal electric blower fans
PTE 880's
Walbro 255 with upgraded SS fuel lines
Aeromotive AFPR
Dsmlink
Wideband
Tial 50mm BOV
external engine oil cooler
Poly engine and trans mounts
Fidanza lightweight flywheel and ACT 2600 clutch setup
Snow performance stage 2 methanol kit
Shep stage 3 transmission
Well the 272's would be less lopey, but you will be able to get the most power with the 280's. If i were running your setup, i would go with the 272's they will be better on the street and keep your idle streetable
272's (I don't care about idle or power in the sub 5K rpm range, I have 280's)...
I kinda tought the 280's were a little to big. Thank you all for the input, guess i have a brand new set of BC 280's still in the sealed box for sale if anyones interested. I had bought them thinking i was going the 2.3 route, but after all other things could not afford the stroker kit. Thank you all for the info and hope i don't lose my shirt selling these
What do you plan on reving it to? I can't believe no one asked that already... If you're looking at an 8,500rpm or higher rev limit, keep the 280's.
  • Wanted 6 bolt NT water pipe
    • chrisman287
