22 wheels fit in eclipse 2g
22s WTF
Why :confused:
...and no they wont fit
Want to trade your GST for my Explorer? :) 22's on an Eclipse? Wow! You've seen those old cadillac's jacked up on 24's and whatnot, right? You'd probably have to do the same thing..
First off, those wheels in the link won't fit without major recontruction and a terrible overall look. Dont' do it.
Second, 22's can be done but, are you sure you want to go there? If this is for show... You will need to modify your struts. This will get expensive. You may need to go with a full coilover setup, for maximum clearance within the wheel wells. Personally, I wouldn't do this for daily use but, it's your car. Below are more ideal specs.
Wheels: 22x7.5" (with the proper FWD offset)
Tires: 235/30-22
i had 19in on my ride any bigger and the wheels will hit part of the srtut.. and also i changed my wheels to 17 in gsx wheels because any big wheel and your gonna slow your car down and take away from handling and also turning.. bad idea unless its just for show.
okay i am buy 20 wheels, in pics i am in last year vewed one eclipse show car with 22 wheels i am only asked. thanks and bye
