2 Problems. wheel bearing? no 1st?
BustedTsi
Nov 29, 2009
Olathe, Kansas
first problem.
Wheel Bearing?
both front left and right seem like at 25mph+ the wheels fell like wobbly like the lugs are loose like thump.thump.thump.thump
little play in the wheel im thinkin both wheel bearings?
and second
i bought this car and he sayed first was out.
it had nothing at first at all
well me and talon913 adjusted the clutch and now it wants to go it starts to roll but bam it pops out and grinds no matter if you hold it in.
its an improvement. think i can bring first back or is it gone?
I would switch both wheelbearings. I had a bearing problem on mine and the noise is very annoying. For the tranny issue you should get it rebuild Im pretty sure your synchros are bad on first gear, and there is no way you are going to fix it by adjusting the clutch, the problem is just going to get bigger to the point where you are not going to be able to shift into first anymore.
  • Wanted 6 bolt NT water pipe
    • chrisman287
