2.75" Downpipe Gasket
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I just put on a punishment racing o2 housing for my external wastegate and in doing so, I am replacing some gaskets. The previous owner installed a megan racing downpipe that has a 2.75" inlet that enlarges to 3". The problem that I have is that I cannot find a 2.75" high temp gasket to connect the downpipe to the o2 housing.
I have searched on:
extremepsi
slowboy
buschur
punishment racing
maperformance
dsmparts
megan racing
Can anyone please help me out.
I know bumping is against the rules here but does anyone know where I can get a 2.75" downpipe gasket?
I think you need a 3" gasket. I have the first version of the 2G AWD Megan DP, mine came with 3" gaskets, and unfortunately the misclocked rear (catback) flange. Not sure, but when Megan fixed that issue they may have also changed the O2 housing flange. The stock O2 housings wouldn't fit with the old version. I ended up getting a tubular O2 just to be able to run the DP.
The piping might only be 2.75" at the inlet, but there's probably plenty of flange material around it to support the larger gasket. Do you know which version you have?
Im not really sure on the version.
I have a 3" gasket because thats what I originally thought it was. It doesnt really line up greatly around where the two bolts go.
  • Wanted 6 bolt NT water pipe
    • chrisman287
