2.0 N/T Head on a 2.0 turbo block???
Robertm1212GST
146
Feb 24, 2008
Spartanburg, South Carolina
Will a 2.0 6 bolt head bolt up to a 2.0 6 turbo block? I know the cams are dif but is everything the same as a turbo head?
Thanks
Robert
I think the grind is the same on the exhaust but the lift is different..I was told a while back that you can use it just use turbo cams. Im sure you have some so just drop those in
