Fox1486
- 131
- 4
- Jul 10, 2004
Rochester,
New York
I just bought a 5spd 99 GST. The car has 117K miles on it and the clutch was just replaced. The problem is first gear. If I am stopped and push the clutch in, the shifter will go into first and I can hear the tranny do the same. Now when I let the clutch out, even slowly, you see the shifter pop back a little bit and you hear the tranny grind. This only happens in 1st and no other gear.
Here is the weird part. It only happens some of the time. So when my father and I were test driving it, he popped the hood and was holding the shifter linkages so it would stay in gear. Sometimes it worked, sometimes it doesn't. He moved the car yesterday into the garage, by himself with the hood down, and the car shifted right into first and had no problem engaging.
We think that it is something with the actual shifter or the linkages in the console, or the shifter linkages under the hood.
Any input would be helpful, thanks.
-Fox
-Fox
