1st gear bogs no reverse
gsx90dsm
Dec 2, 2005
Forest City, Iowa
just installed new cas maf translator was wired into cas rehooked that up with new one now 1st gear bogs down and when i try to put into reverse it grinds. dont know what to do.
Bogging may be due to you need to richen your mixture, or could be a fuel filter stopping up, fuel pump getting weak, or possible cat converter stopping up. These problems should manifest in all forward gears in boost if any of the above things were involved. Grinding may be the clutch needs bled or something along that line. It is an ACT clutch and there's a whole bunch of posts on those.
Good Luck
