1G 1GNT 450cc injectors with Walbro 255
Winetalon
51
Jul 24, 2010
PR, Puerto Rico
hey guys i have a 1g non turbo and recently bought a walbro 255lph and i just wanted to know if i can use this walbro 255lph with 450cc injectors in my car??.I have an apexi safc 2 right now installed in my car and i know i need a fuel pressure regulator with the walbro 255lph as i seen.
You can use whatever ECU the harness is for. There is so much different between the turbo and n/t it's worth it to just get the harness. Oh, and I forgot, you need the injector resistor pack. If you put 450s in on your non-turbo ecu it wouldn't last too long or run at all.
yeah i have the harness from a turbo ecu also.it has the injector resistor pack,the knock sensor and the maf plug that like u said it has 8 pins and the wastegate solenoid valve
