1gb 4g63 n/a coil pack relocation
I’ve seen people mount it to the strut tower but I wouldn’t do that when the factory spot gives you a nice tucked in spot for it. JM fab does or at least did offer a coil pack relocation bracket, also 2g wires are a bit longer and I believe they have to be used with that bracket but it’s also designed to be used with sheet metal intakes with space between the runners, don’t know if everything would fit if you have a stock intake manifold. But, there are options, just start looking up pictures of engine bays and see what others did, but either way 2g plug wires would give you more slack.
I modified a stock 1g coil pack mounting bracket to hang it off of the factory driver side engine mount. Since the mount is attached to the motor, the coil pack & bracket do not move independently from the motor itself. Factory spark plug wire lengths work in this location as well
