1ga 3 piece spoiler on 91 lazer that is spoilerless install?!?
ECLIPSE95
430
Nov 13, 2002
Missoula, Montana
I am buying a lazer here soon and I hate the spoilerless look of it..i do have a parts car my eagle talon with a 3 piece spoiler and i was wondering how I can put this on my lazer and tips and how many drill holes do i have to put in my car and how do I know where to place them? thanks
it'll be alot of work, im currently shaving my wing off my 1Ga and i would say their are atleast 20-25 holes you will need to drill. i can get an exact count if you really want one.
Save yourself some time and swap the entire hatch between the two. If they're different colors get it painted. Painting is easier than trying to drill all those mounting holes. Right?
Heres what you do.
Swap the hatch. There is no point in fighting with the 10 or so holes in the hatch, make life easier and get the right hatch for the spoiler.
Next, the two side peices use brackets at the back, basically you can use the bracket as a template to drill those holes. Then theres only a couple more on each side, I kind of think one of them actually has a cap in the spoiler you pop out, which there again you could use the spoiler as the template for the hole.
Good luck
I thought about doing this to my 91 laser back in the day. I pulled the stock spoiler off a junkyard car and realized the mounting clips were not round but square. The holes were also square WTF So if you find a good way to drill square holes your set otherwise, you can forget that idea like I did.
