JohnnyC
- 204
- 0
- Oct 1, 2003
Bear,
Delaware
Sorry if this has been answered, but I couldn't find an exact answer I'm looking for unless I'm using the wrong search terms.
So, after a couple months of my car missing under acceleration, it started firing only two cylinders a few days ago. (No spark to cylinders 4 & 1)
Since the two cylinders that weren't firing belonged to the same ignition coil, I
started with the ignition coils as far as diagnosing the problem.
I've pulled the coil pack and tested resistances:
FSM Specs:
Primary Coil Resistance 0.77-0.95 ohms
Secondary Coil Resistance 10.3-13.9 K ohms
Actual Specs:
Coil for cylinders 4&1- Primary Resistance 1.1-1.3 ohms - Secondary Resistance - 11.9 K ohms (Questionable Primary Resistance)
Coil for cylinders 3&2 - Primary Resistance .9-1.0 ohms - Secondary Resistance - 13.12 K ohms (All resistances seem to be in spec)
My question is this: I realize that the primary resistances for the coil in question (cylinders 4&1) is technically out of spec, but is it close enough that you think it may not be a bad coil (since secondary resistance is in spec)? Only reason I ask is I can't afford to be throwing parts at it trying to fix the problem at this point, and my next step would be the power transistor which new runs nearly $200. So I don't want to replace this coil if it could still be the power transistor that is at fault, as I won't be able to return the coil if it wasn't the culprit. I'm thinking it is the coil since when my power transistor went bad before, it didn't miss under acceleration like it has been as of late, 2 cylinders just plain stopped firing in that instance.
Any insight here would be helpful.
Thanks!!!
FSM Specs:
Actual Specs:
Thanks!!!
