s15civic
- 0
- Jun 30, 2006
atown,
North Carolina
Hi fellow dsmers,
I need some help with my current setup/situation. The car I acqired from a friend. The car wasn't running due to all but 3 valves bent. But I bought the car for a dirt cheap price for the reason it was already swaped and turbocharged and 2 not a car you see everyday. But once start working on it I didn't know I was in for such a workout, the car was in serious bad shape from the inside to the out but the block was still in great shape. So I redid the interior with new carpet up front, new racing seats, new headliner, remove all the sound deading and speaker equipment and all the back panels painted the rear floor and etc etc. Installed ebay cheap a coilovers and napa camber kit only cause I got shafted out of some kyb agx shocks and h&r springs and the factory springs on the car were sagging really bad but also trying to stay in budget but plan on replacing down the road when get some cash saved up again with better stuff. Anyways on to the main thing the engine. All I have to say to sum it up is ghetto rigged. I still can't figure how the car was so fast with all the ghetto that was going on in there. Parts were held on with caulking and jb weld
So this is were I'm at now. I sold the 14b and bought a hahn racecraft super 16g with a 3"o2 housing with some money left over and bought some polished and lightened rockers and some new bronze valve guides along with a set of 3g lifters. I purchased a set of 1mm oversized valves and brand new valve seals and hks valve springs. Then saved some more money up and brought a set of nippon stage 2 camshafts and a set of bomz cam gears. The head supposly has a light port and polish job done to it already but really can't tell along with the 2g manifold which I def can see and tell that it was. Then after a few weeks bought a home made 3 inch air intake and 2g maf sensor and a 4 inch air filter adapter and foam air filter. Then bought a apexi safc from my friend mike which I also aquired some factory 95 pistons with 20,000 miles on them and a 2g sidemount. At the same time I acquired a set 780cc fuel injectors off ebay and a cheap fuel pressure regulator looks like some obx mess. Now that I have acquired alot of the parts I needed to redo the engine I want take the block and head and send it out to get all the stuff installed.
But I need to know a few things first. Should i get the head ported out again but a lil bit more this time or leave it alone? Should I get the crank knifedged and micropolished? The super1g turbo has the wastegate weld shut and I want to keep the car simi factory looking under the engine bay and don't want to repalce the 2g exhaust manifold do I have another option then buying a set of headers with a wastegate flange on it or could I use a o2 housing the has a wastegate flange welded on it? Could I use a 94 integera fluidyne radiator with fal fans on the eclipse? It fits right in were the stock one use to be but it has the radiator cap on the radiator instead of the water neck so what could I do to fix that. I know to control the fuel injectors I need a eprom chip but do I need to rewire the car cause it runs on a non turbo ecu cause the car was a gs and had a engine swap with a turbo engine and just the wiring harness spliced. And would it be wiser to use a 2g or 1g side manifold. I tried to search to see what one was better but couldn't find anything. I have 2 2g side mounts and was going to put one on each side behind the front vents on my bumper and use alchool injection system to keep temps down cause I want to use the side mounts cause a lot of ppl believe the car is non turbo and with the side mounts hidden they will still believe that. And I also have a vcn2000 nitrous kit that I wouldn't mind using on the car since it's just sitting in my room doing nothing I bought it for my civic but haven't used since I put my civic down would you recomend using it. I can reprogram the computer for it. And what would be better a toyota supra fuel pump or a walbro 255lph? And the car has only a gutted cat and a aftermarket muffler that's really quiet. I would love to keep the car quiet so cops not looking at me all the time. But I have a electric cutout that has a 3inch opening could I fab that after the o2 housing with 3 inch pipe and keep the stock exhast piping after the cat so the car be quiet until the cutout is open and still gain the benefits of having like a full 3 inch exhaust when the cutout is open? I know there are other questions I have but I will leave them up here as I remeber or come into them. Any help would be appreciated thanks.
Nick
Nick
Only reason I thought about the two intercoolers is cause on a audi it's a upgrade says helps the turbo spool up quicker but don't really know if that's true or not and I already have 2 so I was just thinking about that. And the car will be used as a daily driver / weekend strip car for now until my other car is fixed. My budget on the car is 3000 and so far I spent about 1400 but still need the pistons installed and all that. But yeah I was afriad that I would have to replace the manifold :-( but I came across this flange and wondering if this would solve the problem?
. Also if you have any questions on the meth injection shoot me a PM.
. But it does has a t3 flange on it already and uses a adapter to fit the stock manifold so was wondering instead of using that flange use the one on ebay that has a wastegate flange attached to it but would it have any benefits of the wastegate being attached to the manifold instead of this flange?
