1G 1G TCU compatibility
NOSLO2PT0
2,686
250
Aug 31, 2002
Joliet, Illinois
Pretty sure my TCU is shot in my 92 FWD auto car. Bought it as a non-runner. Been sitting for maybe a year. Finally got it running, ECU was toast as the caps leaked and shorted the board. Threw another ECU in, got the car running pretty good. However, it's in limp mode. Haven't checked the codes yet, but it's locked in 3rd gear.
Going through CAPS, I see the TCU's are broken down as such:
91-92 FWD MD750093
93-94 FWD MD754075
91-92 AWD MD750092
93-94 AWD MD754076
My other car is a 94 AWD auto car. I KNOW the TCU in that one is good, but can these things be swapped around like ECU's? Or am I stuck having to try to find a good 91-92 FWD turbo TCU only?
Well to start out the TCUs come in 2 and 3 plug variation. Good place to start would be to take a look and see
92 was a transition year, your TCU could have either three yellow plugs going to it or two.
91 - early 92 = three plug TCU
Late 92 - 94 = two plug TCU
Your car's harness is set up one way or the other. They cannot be swapped..
An AWD TCU would work also, as long as the plugs are compatible..
OK. This is good to know. Guess it's time I pulled it out and found out how many plugs I have. Didn't know there were diff. plug options.
Assuming I find that out, are there any differences between the FWD and AWD TCU's of the same plug configuration?
As long as it has the same amount of plugs your good to go. Even the non turbo TCUs will work, but the shift points will be a lot different.
Anything in the FSM defining the shift points between the turbo/non-turbo units?
AWD and FWD are VERY close to being the same, I would use either without hesitation
1.8 is way off but will work till you find the right one
Havn't tried a 2.0 non-turbo yet
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
  • Wanted 2g Diff ring gear. Internal 98-99 Transmission
    98-99 Manual transmission front differential ring gear. MD770499
    • GIB
