420A 1g Talon radiator in a 2gNT
jayson427
1,515
4
Dec 20, 2011
Mesa, Arizona
so as we all know there isnt a bolt up radiator for a 420a but i found a cool recent thread on 2gnt. this guy mounted a 1g talon radiator (maybe its not the first but its the first write-up iv seen done) in with little fab work you can probably do the neon too. he has a decent sized turbo and it fits alright even tho he had to use flexible hoses, 90 degree couplers and insulation to make it legit. i think its a good option for people that dont want the stock radiator. i thought the hoses would get melted and be in the way but as the pictures show it can be done.
2GNT.com Forums - Viewing message - G1 Radiator is a tight fit.
2GNT.com Forums - Viewing message - RE: G1 Radiator is a tight fit.
He had to make his own hoses, might as well get a 2g Turbo rad and just do the bottom one, the 1G rad is pretty much backtracking.
how many people look under your hood everyday? i know what you mean but its an option if you dont care about cosmetics under the hood.
Yes I meant for it to look good compared to how hacked it is but also I am sure his bottom radiator hose is like 3 feet long and at that point why bother?
It just doesn't make since to me to do this with out making custom metal line (not specifically -AN lines but like 1" stainless steel) instead of cobbing a mess together with hoses from advanced auto.
  • Wanted 6 bolt NT water pipe
    • chrisman287
