1g problem
bizkit8587
Sep 24, 2004
macungie, Pennsylvania
a while back i blew the timing belt on my 93 talon ES, well i finally go to workin on it (because im going broke real fast) and bought a new/used head for it. new gaskets..etc. we put it all together and lined up the timing marks perfectly, but we did break a bolt on the alternator so we jus tried to crank it to see if it would start without...well we got a little crank out of it then we tried to turn the bottom sprocket and it would only turn a little bit, it seems like its hitting something solid. the pistons can only move like a 90 degree turn on the sproket. Im so boggled right now! help if possible.
these are pics of the bottom half after takin the old head off (broken valves)
well.i have pics but they wont load on because there to big. arg!
Did you make sure the auto tensioner arm space was around 4mm?
