1g n/t header question
Tymon1986
Oct 5, 2011
Warsaw, Europe
Hi!
Will I Able to mount OBX header to my 92 Eclipse N/T to stock Exhaust and dont cut off the catalyst?
It should be fine if its a cast header, which I assume the stock one is. You might have a slight issue if your new header is tubular, if its a 4-1 header you should be just fine. However if your header is a 4-2-1 you will probably run into some issues, nothing some cutting and welding cant fix.
Yeah since the header comes down a little bit further so you will have to get the sparks flying, but 4-2-1 sounds soooo much better than just a 4-1. In my opinion at least. But as far as customization goes, you could easily do it yourself, if you took it to a shop it couldnt be more than $150. maybe $200 tops.
The question is: After installation I get maybe 1-2HP or just lose some power? The sound will be deeper? Please help
  • Wanted 6 bolt NT water pipe
    • chrisman287
