1g into 2g swap
margro165
Aug 25, 2007
hamilton, New Jersey
ok im doin a 90eclipse motor swap into a 96 eclipse swap. the motor mounts dont line up. seeking advice. also do the wiring harness line up or should i pull the wiring harness from the other car. im new to the dsm so all help iz greatly appreciated......thanx:thumb:
A 2g n/t has a chrysler engine, The motor mounts and wiring harnesses are completely different, doing a 420a to 4g63 engine swap would be extremly hard and expensive.
Assuming your profile is correct, your NT has a 420a motor in it and you are trying to drop in a 4G63. This is not only a difficult task to perform (because of the motor mounts not lining up, etc.) It would not be a cost effective solution. If you are adamant about it, check out 2gnt.com for more information or search around the forum a bit more.
Hey there, Welcome to the forums! :thumb: You say the motor mounts don't line up? You are using the 2.0L DOHC engine right? The 1.8L SOHC would be much different.
As well, the search function on this forum is amazing:) I found these 2 sites which will most likely be of much help to you! PS. In case you do not know 6bolt refers to 1G engines, 7bolt refers to 2G engines(94.5((i believe)) and up)
6Bolt Swap
1G Swap
EDIT: The 2 guys above got their .02 and info in before I finished...their info would be correct.....but those 2 links still provide answers to putting a 1g engine into a 2g :)
6Bolt Swap
1G Swap
...he's running a 420a. Those links refer to putting a 6bolt turbo engine into a 2g turbo car.
thanx for the info. im pullin the ecu and the wiring harness for that motor. and we decided that we are goin 2 build custom mounts to get it 2 drop in.....:thumb: if you got anything else that would b great.
If you're serious about this and actually get somewhere. Do the entire community a favor and document your swap. Many 2g nt guys have thought about it and I have yet to see someone successful at it. If you get the ball rolling and need some help, I'm in bridgewater and can always swing by to help.
thanx im in hamilton, nj. you can hit me up at [email protected]. just im me n i will get your number my name is marcus, or you can hit me up at myspace.com/margro165. the swap is definitly goin to happen if you aint bust this weekend i will be pulling the wiring harness and the ecu. im all bout the 240sx. this is my first eclipse so what eva help i can get i will take. we are desciding to weld on new motor mounts. but that still in the thinkin process. but im me it will bo to my fone and i can get back at you.........thanx,:thumb:
