1g 7bolt swap into 2g talon HELP!
Mulfordautomotive
Dec 11, 2012
Muncie, Indiana
ok I have a 1992 turbo laser 7bolt that I am going to swap into a 95 talon, I cant find anything on the forum about doing that kind of swap, can someone help me out here? I see all stuff about 6bolt into a 2g but not anything about a 1g 7bolt into a 2g.:ohdamn::banghead:
reason I am asking about this is I have a 92 laser fwd turbo with 7bolt that I want to swap into the 95 talon
Well all 2Gs come stock with a 7 bolt so the only problem your gonna run in to is the CAS wiring. You can either buy a 2g to 1g CAS wiring plug or just manual do the wiring yourself.
Unless you have a 2ga head then you can put that on and it shouldnt ba aproblem.
There is little info on what is you all have from talon that is left on the car. Do you have a motor in the talon? Wiring harness in the talon? This could be all useful info to us.
Talon has stock 7bolt still in it car spun bearings ### the guy I got it from hooked up the oil lines to the turbo wrong and seal blew and I lost the bottom end, block is still good and everything but I just need to get it running in a hurry, in short I have everything for the 2G
