1G FWD Fuel Pump Rewire Kill Switch [merged 10/4/06]
booosting92tsi
90
Nov 1, 2004
Philadelphia, Pennsylvania
I'm planning on doing a 1g fwd fuel pump rewire. I also want to put a kill switch on this fuel pump wire. By putting a kill switch in the fuel pump wire, will that affect the voltage? Will it defeat the purpose of the whole fuel pump rewire mod???
what kinda switch should i use, anyone out there done this???
:talon: :talon: :talon: :talon: :talon:
A simple high amperage toggle switch will do the trick. All you would need to do is put it in line with the power feed to the fuel pump.
I have personally only done this on race only cars, and it works fine.
If your switch is mounted in an easily bumped area; insight or not. You may do well to use a covered toggle. Sort of like the ones used to engage fire control of missiles in a jet fighter. I don't think loss of fuel flow during a full throttle run would be a good thing.
Maybe you have kids that like to fiddle with things; you may find a covered switch less tempting for them to play with... or not!
This leads me to suggest the clutch switch. Do to its OEM functionality, theres less a chance of any adverse affects to engaging it under normal driving conditions.
