DECODER22
Supporting VIP
- 325
- 9
- Jul 20, 2004
Janesville,
Wisconsin
What seal should be used for running the ELHS, Would using the stock 1G fwd axle seal cause a leak?
Parts needed:
- AWD intermediate shaft
- AWD Drivers side axle
- 1 MD707184 1g FWD output shaft seal
- 2 MB297860 Bolts which attach the intermediate shaft to the block
- 2 MF450406 Lock washers for the above bolts
- 1 MB297732 Spacer which is only needed if A/C compressor bracket is removed
- 2.3 quarts of transmission fluid (SAE 75W-85W gear oil was recommended from the factory)(Redline MT-90 is recommended by most DSM transmission specialists).
